04-02-2021 05:49 AM
Does anyone know how to get the display values from a List field within an inline script in Flow Designer?
Here is the information:
- List field is on the core_company field called "u_sub_id"
- The flow runs against a catalog item that contains a reference variable (called "customer") that references [core_company]
- Within the inline script, I want to return the first entry in the List field into a variable. Since the variable references core_company, I can dot-walk to the "u_sub_id" field. However, when I print out the results of the variable to the log, it is returning "object GlideRecord".
Here are some of the things I've tried in the inline script:
// _2__update_record is updating the RITM record
04-02-2021 06:28 AM
how the values in the list field looks like?
So are you saying it is only returning only the 1st choice
can you share the image how many choices that list field has
As an alternative can you try this
var rec = new GlideRecord('core_company');
rec.addQuery('sys_id', fd_data._1__get_catalog_variables.customer);
rec.query();
if(rec.next()){
return rec.u_sub_id;
//OR
return rec.u_sub_id.getValue();
// OR
return rec.u_sub_id.getDisplayValue();
04-02-2021 06:42 AM
So how many values are there for this record for Sub ID?
04-02-2021 06:45 AM
In most cases, there will be just 1 value however, in some cases, a company can have many values within the Sub ID. It isn't a choice list; users manually enter a value(s) in the Manual Sub ID and when he/she saves the record, they are stored in the Sub ID.
I've tried the approach to query the core_company table and that returned the value I needed!
04-02-2021 06:56 AM
Glad to help.
Please mark response as correct and helpful.
05-26-2022 09:32 AM
07-16-2021 04:48 PM
How do you access the fd_data variables in Flow Action?
I tried your example:
// ... code ...
var account_name= fd_data.trigger.request_item.variables.account_name;
gs.info('Account Name is: [' + account_name+ ']');
})(inputs, outputs);
I'm getting this error:
Error: "fd_data" is not defined.,Detail: "fd_data" is not defined.
Any ideas?
