Flow Designer | Scripted Approval is not working
IAmIshan
I have one catalog item and it has only two fields:
1.Requested for
2.Select Group
Once request is submitted, it will trigger approval to selected group's manager. and for this I have written script (I know we can use get variables action and we can do it without writing script for it) in Rules field, and it is working fine
var appr = fd_data.trigger.request_item.variables.select_group.manager;
return "ApprovesAnyU["+appr+"]";
It is triggering approval to approver but immediately updating request as Rejected.. ideally it should be requested/pending.. but thats not happening.
@Shamma Negi - Thanks for your response!
Actually, there was an issue with the script. I replaced it with the below script in Rules it started working fine.
gs.log('Group Manager SysID: '+appr);
gs.log('Group Manager Display Name: '+appr.getDisplayValue());
return 'ApprovesAnyU[' + appr + ']OrRejectsAnyU[' + appr + ']';
Shamma Negi
Check there is one Business Rule or any other script which does this if the condiiton is met.
Please check the business rule in your instance.
Shamma
Regards,Shamma Negi
