How can I automate catalog request using flow designer.
JLeong
Hi all,
I need to automate the creation of catalog request based on a condition in Flow Designer. The  action "Create Request"  in Flow Designer is not functional. Could I just create a record? Which table should I use to create a record so it will create the request and the item?
Thanks in advance.
Jocelyn
2 ACCEPTED SOLUTIONS
Sebastian R_
I think it´s not possible to create a request/request items through Flow Designer directly.
However you can use the Cart-API to write your own Flow Action which generates the request and request item.
https://docs.servicenow.com/bundle/madrid-application-development/page/script/server-scripting/refer...
JLeong
There is now a built-in action called Submit Catalog Item Request
Sebastian R_
Thank you so much Sebastian! I will try this.
Jocelyn
JLeong
