12-02-2020 11:21 PM
Hi all,
Please help me with this below requirement.
We are using incidents properties OOB to move incidents to closed state after 5 days once the incident state is set to resolved. This will run in weekends as well. can we restrict this to run only for 5 working days in a week.
If yes please help me with the right way to achieve this.
Thank you,
Balaram.
12-03-2020 04:50 AM
Create schedule job which runs daily and use below script
It would check if the days between created and now time is more than 5 working days i.e. the difference is excluding weekends
updateRecords();
function updateRecords(){
try{
inc.addQuery('state', 6);
inc.query();
while(inc.next()){
var start = new GlideDateTime(inc.sys_created_on);
var nowTime = new GlideDateTime();
var days = getDateDiffExcWeekends(start,nowTime);
// if days more than 5
if(days >=5){
inc.state = 7;
inc.incident_state = 7;
inc.active = false;
inc.update();
catch(ex){
gs.info(ex);
function getDateDiffExcWeekends(start , end){
var days = 0;
while (start < end) {
start.addDaysUTC(1);
if (start.getDayOfWeekUTC() != 6 && start.getDayOfWeekUTC() != 7){
days++ ;
return days;
12-03-2020 04:50 AM
updateRecords();
try{
inc.query();
while(inc.next()){
if(days >=5){
inc.state = 7;
inc.active = false;
inc.update();
catch(ex){
gs.info(ex);
var days = 0;
days++ ;
return days;
12-28-2020 04:24 AM
Hope you are doing good.
If so, please mark appropriate response as correct & helpful so that the question will appear as resolved for others who may have a similar question in the future.
Thanks!
11-22-2021 04:34 AM
I need same logic, for resolved.
That is when an incident goes to resolved after 5 week days it has to close automatically. please suggest
01-30-2022 04:45 AM
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
03-09-2022 01:46 AM
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
