How to change color of dot before incident with respect to SLA
pushparaj
Mega Contributor
Hi we have a requirement like in the ITIL home page we need to display a dot before incident number which is based on SLA duration
No Dot if SLA duration is   <80%
Amber (orange) dot when SLA hits 80% duration
if SLA breached or touched 100% then a red dot needs to be shown.
( see the image attached)
Pls describe how can i achieve this.
Thanks in advance
sraghunath
I am able to achieve it using below code: and its working fine for me:
In Style : value :: javascript:DotColorerSLA() > 80
                            Style :: background-color:red;
Script Include :--> DotColorerSLA()
function DotColorerSLA() {
              var per = '';
              var gr = new GlideRecord('task_sla');
              gr.addQuery('task', current.sys_id);
              if(gr.next())
                      per = gr.business_percentage;
              //gs.addInfoMessage("per-->"+per);
              //gs.log("per-->"+per);
              return per;
PS: Hit like, Helpful or Correct depending on the impact of the response
13 REPLIES 13
How are you testing it ? Field styles with javascript: will work only on list layout and not on form layout.
Also the 'new' keyword is missing in the field style call.
Syntax:
javascript: new scriptincludename().functionname();
I have been verifying it in list layout only not in the form.
and i have been using "==" only i pasted here wrong by mistake.
and after all this any idea why the indicator is not appearing in the list view.
sraghunath
              var per = '';
              if(gr.next())
              return per;
ravin
Giga Contributor
Your solution was very much helpful dear !!! Thank you !
