How to change OOB worknote display format.
Gauri Patil
Hello All,
We have a requirement that  whenever case Date Fixed field is updated by the system, I should see the following system activity logged:
1] When case is updated to Resolved or updated from Resolved to an active state(i.e., New, Open, Assigned, In progress, Acceptance Test, On Hold) , where the system sets Date Fixed field with current date/time, I should see the field change activity logged by the system:
a] "Date Fixed [DATE/TIME] was blank".
2] When case, with Date Fixed date/time set, is updated to Closed or cancelled - system does not change Date Fixed field in this situation, I should not see Date Fixed activity logged.
3] System Field changes activity, when logged should look similar to the picture below image no. 6
7] Here's an example when the case is updated FROM Resolved to an active state should look like : image no. 7
@Dr Atul G- LNG  @Maik Skoddow  @Danish Bhairag2  @Anil Lande  @Tai Vu
Any help will be appreciated !!
Thank you!
Anil Lande
I guess you are looking to add 'Date Fixed' field in the activities same as other fields. Check below links to configure the activity fields.
https://docs.servicenow.com/bundle/tokyo-platform-user-interface/page/administer/form-administration...
https://www.servicenow.com/community/developer-forum/how-to-delete-field-change-entry-in-activities/...
Please appreciate the efforts of community contributors by marking appropriate response as correct answer and helpful, this may help other community users to follow correct solution in future.
Anil Lande
Tai Vu
Hi @Gauri Patil
Have you tried to added the Date Fixed field to the Filter Activity?
Sample.
Ref: Configure the activity filter
Cheers,
Tai Vu
