08-09-2019 04:07 AM
can you help me how to copy Approval comments into RITM, REQ, when RITM was REJECTED.
Not Working
here Approvals comments copying to RITM, but Not copied into REQ.
approvalcomments();
function approvalcomments()
var grr = new GlideRecord('sc_req_item');
grr.get(current.sysapproval);
grr.comments = current.comments;
grr.update();
var gr = new GlideRecord('sc_request');
gr.get(gr.request);
if(gr.next())
gr.comments = current.comments+" " +gr.number;
gr.update();
08-09-2019 05:20 AM
Working example from my PDI (= tested). Working for Approvals on RITM.
Kind regards,
Mark
08-09-2019 04:15 AM
Hi there,
Hard to say exactly for your situation, I don't know how your approval is setup, custom field, etc..
Though an approach could be:
onBefore Business Rule, Update checked, Condition (or thru condition builder) State changes to Rejected.
The scripted:
Example for only the RITM!
if(gr.get('sysapproval')) {
gr.comments = "Comment copied from approval record:\n\n" + current.comments;
gr.update();
})(current, previous);
I personally don't like the onBefore + in the script an update on a different record. Though, I think because of the comment type field on your approval, you will need to do onBefore.
Add a gs.info message to the Business Rule, with which you can verify if your Business Rule got triggered. Before moving to production, remove the gs.info message.
Kind regards,
Mark
08-09-2019 04:19 AM
approvalcomments();
grr.update();
gr.get(gr.request);
if(gr.next())
gr.update();
08-09-2019 05:11 AM
Looking at your script, that's correct:
gr.get(gr.request); is nothing yet. So you are not getting a sc_request record.
Kind regards,
Mark
08-09-2019 05:20 AM
Kind regards,
Mark
08-09-2019 05:45 AM
in case if WE have REQ level Approvals presented on REQ, then is it correct???
reqapprovalcomments();
function reqapprovalcomments()
var gr = new GlideRecord('sc_request'); // if REQ had approvals
gr.get(current.sysapproval);
gr.comments = current.comments;
gr.update();
var ghh=new GlideRecord('sc_req_item');
ghh.get('request',gr.sys_id);
ghh.query();
while(ghh.next())
//gs.addInfoMessage("RITM numbers is"+ghh.number);//
ghh.comments=current.comments;
ghh.update();
