How to create a form in service portal to create a ticket in my custom table
vamshivemula
I am having a custom table, how to create a form for that table in service portal to create tickets, and also any one explain me how to create a widget for that custom form in the service portal home page.
Process flow:
-> in service portal home page I need a widget for my custom form.
-> once I click it, it has to show me the form
-> after filling the form if I click submit it has to create a ticket in my table.
My aim is to give the that custom module from service portal.
Can any one please help me in this regard. Thanks in advance.
Thanks & Regards,
V Vamshi Krishna
michaelskae
Hi Vamshi,
Do you need to create a new widget at all?
The "form" page includes the "Form" widget which renders the fields on the standard form view on the Service Portal page.
A new record has sys id=-1, so as long as you supply the name of our table in the URL, the new record form will be displayed for this table.
For example, if your custom table is "u_test", use the URL:
https://<instance>.service-now.com/sp?id=form&sys_id=-1&table=u_test
Fill in the form, then click Save. The record will be created, and will reload the page with this new record.
Mike
I had a similar requirement and this resolution worked for me 🙂 Thanks Mike.
I have a similar requirement. Did this work? Also where am i supposed to provide the URL in form widget.
Please suggest.
patricklatella
Hi Vamshi,
I have a very similar requirement to build a custom form widget for providing a form in Service Portal...were you able to get yours built?  Would you mind sharing if so?  thanks!  Patrick
