how to dot walk in script include
Sweety11
Hi all,
I'm little bit confused, like how to link the fields from 2 different tables.
Ex: sys_user & cmn_location. In user table i can able to see city & country fields but the field names are populating as location for both. In this case I want to get those particular 2 fields from location table. How I do that in script include?
Sys_user > city want to get from cmn_location > city
Need some detailed understanding. Your inputs helps me to do this thing.
Sweety.
26 REPLIES 26
Actually I didn't missed it Ankur, I have tried that tooo but I'm not getting the values.
If I put the logs in script include, it's not returning any thing
Why don't you add some logs and alerts to debug your script?
Also while testing test with user who have all values filled like location, city, country.
var displaydetails = Class.create();
displaydetails.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    details: function() {
        var user = this.getparameter('sysparm_select');
gs.info('1234 Received user :'+user);
        gr.addQuery('sys_id', user);  // use sys_id if passing sys_id
        if (gr.next) {
gs.info('1234 record found City :'+gr.location.city.toString());
gs.info('1234 record found country :'+gr.location.country.toString());
            var obj = {
                'ucity': gr.location.city.toString(), // in place of city what is the field name have to pass
                'ucountry': gr.location.country.toString() // same for country too
            return JSON.stringify(obj);
    type: 'displaydetails'
And try below:
function onLoad() {
var user = g_form.getValue('requested_by');
var ga = new GlideAjax('displaydetails');
ga.addParam('sysparm_name', 'details');
ga.addParam('sysparm_select', user);
ga.getXMLAnswer(UserDetails);
function UserDetails(response){
alert('Received Resp : '+response);
var obj = JSON.parse(response);
var city = obj.ucity;
var country = obj.ucountry;
g_form.setValue('city', city);
g_form.setValue('country', country);
Please mark helpful and correct if applicable.
Teju D
Hey Teju,
I have tried by adding logs into the script.
The messages I'm getting are
1234 Received user :undefined
1234 record found Country :
I'm not getting any values in city and country
Sweety.
Sweety11
How to glide the sys_user table and cmn_location table to get this requirement?
@ Sweety
Check my above response.
