How to get Subject in email template body
ryancox
Giga Contributor
Is it possible to get the Subject of a notification to be used in the body of a template?
I am trying to use templates more often and I would be helpful if I could pull the subject from the notification that is using the template into the body of the email.
Make sense?
Hmmm, interesting one, I tried the above one but did not work so I explored the more options and came out with solution.
Put the below code where you want the subject to be printed inside the body of the notification email template.
<mail_script>
template.print(email.getSubject());
</mail_script>
BIngo. I even thought about that early on because I know you can set the subject that way. Guess I should have tried first. Thanks.
This is EXACTLY what I needed without having to think too much!  Thank you!
