How to restrict incident fields for non ITIL users
How do i make all incident fields read only using ACL
User should be assignment group or is the caller or has itil_admin role to edit fields if these conditions are not met the fields must be read only.
C
Hi Shloke
Tried the above fields are still editable and not read only.
Hi @Carol
In the above ACL you need to select * to apply it as Field Level ACL. Currently you have just selected the Table Name an other columns there is nothing which makes it act as a table level ACL.
So please update your ACL as shown below:
Please make sure you implement your ACL as below format:
Table Name *
Also please make sure you update the same script in ACL links shared above.
This is working for me in my PDI and have tested it.
Shloke
Shloke
