I'm using postman and trying to create record in servicenow.. but I'm getting error as "user not authenticated"
Sathwik1
For instance SSO was enabled.. i.e., Okta.. so what things I need to take care?
I want to achieve this only by using Basic Authentication..is it possible?
I think it is not possible with Basic authentication type you need to use any other.
Hope you it helps you.
Please Mark Correct/helpful if applicable, Thanks!!
Pavankumar
If it helps please click Accept as Solution/hit the Thumb Icon.
ServiceNow Community MVP 2024.
Pavankumar
PavanK960672992
Mega Patron
Hi @Sathwik
If it is resolved please Mark Correct as well so that it will displays in top search and users will get benefit if they have similar question.
Hope you understood my point.
Pavankumar
Pavankumar
