Issue with integration
Sarah Bouil
Hello All,
The Endpoint is not mapped correctly, it's pointing to my instance: https://xxxx.service-now.com but it is not correct and hence the Response body is empty also. What could be the issue please and I am not sure where exactly need to verify it?
Sorry to confuse you. My REST message Endpoint is: ${targetInstance}/api/test/a1/aqcc_testdev/inst_task but when I execute it I can see it is updated to https://xxxx.service-now.com instance only.
As per my REST message it should be like this: https://xxxx.service-now.com/api/test/a1/aqcc_testdev/inst_task
Pratiksha
If i understood correctly. You are trying to modify the end-point and not sure where to modify. To do this : you need to check the rest messages. To form end point correctly you can use REST API explore.
