Issue with ordering
Sathwik1
In a catalog item I had a field which refers to the "Variable" table..
and in that I used the below reference qualifier...and it is working fine...but here issue is...
with that reference qualifier for example....if I am getting output like below...
test
example
success
Customer needs output like this....
success
test
example
they need success variable first....and remaining in ascending order... is it possible?
Used below reference qualifier.
cat_item=b3819567rtg79b0678u992y6ub9423f^nameNOT LIKEmainfield^active=true^nameNOT LIKEstart^name!=field1^ORname=NULL^name!=field2^ORname=NULL^name!=field3^ORname=NULL^name!=field4^ORname=NULL^name!=field5^ORname=NULL^name!=field6^ORname=NULL^name!=field7^ORname=NULL^name!=filed8^ORname=NULL^name!=ffield9^ORname=NULL^name!=field10^ORname=NULL^name!=field11^ORname=NULL^name!=field12^ORname=NULL^name!=field13^ORname=NULL^NQsys_id=c1954d7dbe9001462c4fefer5c964332^ORsys_id=t54ea45r4re5423r4c4fe9b045r431^name!=field67^ORname=NULL
@Ankur Bawiskar
you can decide the field on which you want to order from the item_option_new table
[Variable attributes] may not be visible for you OOB. If so, you may need to modify your layout to add it in and then set the sort field.
Bobin1
