Lookup Record not selectable for approval - Flow Designer
depa
the background is what i want to archive is that every account has one contact with a admin role who will approve the request.
For a flow approval i dont get the record selectable and i dunno why(grey). In my if condition i want to return the record which is queried with the condition in 4.1.
Thanks for help
Dape,
Ahh okay, approver field is referenced from User table and you are trying to insert approver from Contact[customer_contact] table. Do you think this might be the reason?
Please mark this correct & helpful if it answered your question.
Thanks & Regards,
Sharjeel
MrMuhammad
Hi Dape,
Save the flow before using Look up record in the Ask for Approval step. I hope this will fix the issue.
Thanks & Regards,
Sharjeel
depa
Hi sry thats not the problem.
you need to directly drag and drop the pill from right side and place it
please find below screenshot
If my answer solved your issue, please mark my answer as ✅ Correct & 👍Helpful based on the Impact.
Any idea?
