Make Comment and Additional comment mandatory when RITM is moved into different state
BKSharma
I've below 2 requirements -
1. When a RITM is moved by an 'agent' from 'Open' to 'Work In Progress', "Additional Comments" (instead of Work Notes) must be mandatory.
2. When a RITM is moved by an 'Assignment Group member (non-assignee)' from 'Open' to 'Work In Progress', both "Additional Comments" and "Work Notes" must be mandatory.
How I can achieve above 2 things.
@BKSharma
Something like this but please enhance
I assume you are checking some agent role in your 1st point.
Script Include: It should be client callable
var RITMAgentGroupCheck = Class.create();
RITMAgentGroupCheck.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    isAgent: function() {
        var userId = this.getParameter('sysparm_user_id');
        // Check if user has 'agent' role
        if (gs.getUser().hasRole('agent'))
            return 'true';
        return 'false';
    isAssignmentGroupMemberNotAssignee: function() {
        var ritmSysId = this.getParameter('sysparm_ritm_sysid');
        var ritmGR = new GlideRecord('sc_req_item');
        if (!ritmGR.get(ritmSysId))
            return 'false';
        var assignmentGroup = ritmGR.assignment_group.toString();
        var assignee = ritmGR.assigned_to.toString();
        // Check if user is in assignment group but not assigned_to user
        var groupMemberGr = new GlideRecord('sys_user_grmember');
        groupMemberGr.addQuery('group', assignmentGroup);
        groupMemberGr.addQuery('user', userId);
        groupMemberGr.query();
        var isMember = groupMemberGr.hasNext();
        var notAssigned = (userId != assignee);
        if (isMember && notAssigned) {
            return 'true';
        return 'false';
onChange client script: State field
    if (isLoading || newValue !== '2') // 2 = Work In Progress state, adjust as needed
    var ga = new GlideAjax('RITMAgentGroupCheck');
    ga.addParam('sysparm_name', 'isAgent');
    ga.addParam('sysparm_user_id', g_user.userID);
    ga.getXMLAnswer(function(agentResponse) {
        if (agentResponse === 'true') {
            // Agent moving RITM: Additional Comments mandatory only
            g_form.setMandatory('additional_comments', true);
            g_form.setMandatory('work_notes', false);
            // Check assignment group member condition
            var ga2 = new GlideAjax('RITMAgentGroupCheck');
            ga2.addParam('sysparm_name', 'isAssignmentGroupMemberNotAssignee');
            ga2.addParam('sysparm_user_id', g_user.userID);
            ga2.addParam('sysparm_ritm_sysid', g_form.getUniqueValue());
            ga2.getXMLAnswer(function(memberResponse) {
                if (memberResponse === 'true') {
                    // Assignment group member (non-assignee): Both mandatory
                    g_form.setMandatory('work_notes', true);
                    // Otherwise, clear mandatory (optional)
                    g_form.setMandatory('additional_comments', false);
I believe I have answered your question and you can enhance it further based on your requirement and developer skills.
9 REPLIES 9
@BKSharma
you can check and pass the logged in user & form assignment group to GlideAjax function and then in that check if that user is part of that group or not
based on that derive your logic.
Hi @Ankur Bawiskar ,
Can you please provide me sample On Change Client Script and Glide Ajax for this functionality ?
@BKSharma
            return 'true';
        return 'false';
            return 'false';
            return 'true';
        return 'false';
@BKSharma
Hope you are doing good.
