Need help with an Assignment Rule that is not working
bostonsnow
I'm pretty new to SNOW so please bear with me on this post.
For all Incidents that are coming in through our Service Portal, I am trying to auto-assign the Assignment Group based on the Business Service that is selected. I have created an Assignment Rule as follows (I first test just Business Service = X but it didn't work so I tried adding more conditions)...
State = New
Contact Type = Self Service
This is the only active Assignment Rule I have. No matter what I try, the Incident is also set to a different Assignment Group (our Tier 1 Group).
What could be happening upstream that are setting the Assignment Group before the Assignment Rule? The form on the Service Portal to submit an Incident is a Record Producer on the Incident table. Is there any SNOW debugging I can use to see exactly what is setting this Assignment Group?
Thanks!
Mike
harishdasari
Hi Michael,
you want to set the assignment group automatically as soon as business service is set.. am I understood your requirement correctly
If I understand correctly, please use the client script
On change client script
On change field : Business service
var bs= g_form.getReference('business_service', setAssignmentgroup);
function setAssignmentgroup() {
    if (bs)
            g_form.setValue('assignment_group', bs.assignment_group);
This will set the assignment group.
Thank you
Hello Harish,
Thanks for your response! The Business Service is selected by the Portal user when the submit a new Incident. So I'm trying to have the Assignment Group automatically assign when a new Incident comes in and has a specific Business Service set.
Thanks!
Mike
Hi Michael,
Yes please you can use the client script I have suggested.
please set the UI type as ALL. so that this On-Change client script will also work in service portal as well
Use the Business service in this field name
use this code below.
var sg = g_form.getReference('business_service').support_group;
g_form.setValue('assignment_group', sg);
Mark this answer as correct, if your issue is resolved.
Thank you.
We are getting "Missing function declaration for onChange"
