Need to copy worknotes from incident to incident tasks
Anjaneyulu1
Giga Contributor
Hii All,
I have written script like this,
when to run - after update
condition - work notes changes
script -
var inc = new GlideRecord('incident_task');
inc.addQuery('incident.sys_id', current.sys_id);
inc.query();
while (inc.next()) {
inc.work_notes = current.work_notes.getJournalEntry(1);
inc.update();
my script is not working but in place of worknotes if i place comments then it is working.
i don't know why it is happening like that.
please help me where i have written mistake here.
Hi Anji,
I just tested again and it is working:
If this answer is helpful please mark correct and helpful!
Christopher Perry
20 REPLIES 20
This is not happening for me in my personal instance. Can you check if you have written any other BR which runs on update of work notes or you have used current.update() in a before business rule.
There is no issue with this script and the functionality you are trying to achieve. We now need to look into some other areas.
Deepankar Mathur
Strange.
Try below & confirm the infomessages you get.
gs.addInfoMessage('BR works');
inc.query();
gs.addInfoMessage(inc.getRowCount());
gs.addInfoMessage('Inside loop works');
inc.update();
Hii Jaspal, I have sorted it out but if I post worknotes in parent incident then in activity logs the worknotes message is appearing 2times in parent incident and in incident tasks worknotes is displaying correctly.
Please tell me how to sort it out.
Can you paste the final script you using now.
Hii, In addquery replace just incident.
