Problem task must be completed before closing the problem form
NishaB
Hi
I want a task to be done. I want to close my problem record if only all the problem tasks are closed. Otherwise an error message has to be displayed. How to configure this?
5 ACCEPTED SOLUTIONS
Vishal Jaswal
Tera Sage
Hello @NishaB
Create a before business rule on problem table:
var problemTasks = new GlideRecord('problem_task');
problemTasks.addQuery('problem', current.sys_id);
problemTasks.addQuery('state', '!=', '3');
problemTasks.query();
if (problemTasks.hasNext()) {
gs.addErrorMessage("Cannot close the problem record because not all problem tasks are closed.");
current.setAbortAction(true); // Prevents the record from being saved
})(current, previous);
Shivalika
Hello @NishaB
Create a "Before Update" BR - with condition as state "changes to" "closed" and add below 👇 script
// Trigger only if state is changing to 'Closed'
if (current.state.changesTo('Closed')) {
    // Check for any open Problem Tasks
    var taskGR = new GlideRecord('problem_task');
    taskGR.addQuery('problem_id', current.sys_id);
    taskGR.addQuery('state', '!=', 'Closed');
    taskGR.query();
    if (taskGR.hasNext()) {
        gs.addErrorMessage('Cannot close the Problem record because one or more Problem Tasks are still open.');
Make changes as per your field names.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this questions from unsolved to solved bucket.
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeEISQCY
Ankur Bawiskar
@NishaB
you can use before update business rule on problem table and use GlideAggregate to optimize rather than using getRowCount()
Condition: State Changes to Closed/Resolved
Script:
    // Use GlideAggregate to count problem tasks that are not closed
    var agg = new GlideAggregate('problem_task');
    agg.addQuery('problem', current.problem); // Filter by the current problem record
    agg.addEncodedQuery('stateNOT IN3,4,7'); // Count tasks that are not closed
    agg.addAggregate('COUNT'); // Aggregate the count of matching records
    agg.query();
    if (agg.next() && parseInt(agg.getAggregate('COUNT')) > 0) {
        // If there are any open problem tasks, display an error message
        gs.addErrorMessage('Cannot close the problem record because there are open problem tasks.');
        current.setAbortAction(true); // Prevent the problem record from being closed
@NishaB
Hope you are doing good.
As per new community feature you can mark multiple responses as correct.
If my response helped please mark it correct as well so that it benefits future readers.
Vishal Jaswal
Tera Sage
Hello @NishaB
Shivalika
Hello @NishaB
    taskGR.query();
Shivalika
Anoja
Hi @NishaB ,
Create a business rule on problem table.
  var gr = new GlideRecord('problem_task');
  gr.addQuery('active',true);
  gr.addQuery('problem',current.sys_id);
  if (gr.next()) {
gs.addInfoMessage('Close all the related Problem tasks.');
