Reference Field : How to sort the results in descending order using reference qualifier?
kutvaram
I have a variable of reference field type with simple condition in it.
I need to sort the results by a column in descending order.
I used variable attributes section where ref_ac_order_by=columnname.
This is doing ascending order sorting.
How to do it descending order sorting by a column name?
I have referred many community links and also got to know , have to write query business rule. But I am not happy with that.
Kindly advise using variable attributes sorting by descending or a better way.
Ram Prakash K R
Can you try like this
var encodedquery = "sys_created_on>=2020-12-14^sys_created_on<=2020-12-15 23:59:59";
Narsing
22 REPLIES 22
Hi Narsing,
I tried the above suggestion and it worked.
Thanks a lot 🙂
Its a great help!
Ram Prakash K R
Sagar Pagar
Hello Ram,
Try ORDERBY or ORDERBYDESC in advanced reference qualifier. It will give you expected result.
javascript:'filter_query^ORDERBYcolumnName';
OR
javascript:'filter_query^ORDERBYDESCcolumnName';
For example:
javascript:'active=true^ORDERBYname';
Sagar Pagar
Hi Sagar,
It is not working.
Ram Prakash K R
