Wait for condition in scheduled job script.
Ajay37
I am using a schedule job, where I am querying the records from a table and doing some action for the retrieved records. Now I want to have delay between each record to get that action done (one after the other after few seconds). Could anybody has an idea?
Hi Ajay,
Yes, you can use that way. You would need to use it after you write gr.update() statement so that system will keep delay after every update as per your requirement.
Note: Consider delay timing before executing script e.g. If you are updating  1lakh records then keeping 1 seconds delay for each record will take more than 24hours.
Please mark this as Correct or Helpful if it helps.
Thanks and Regards,
Abhijit
By marking my response as correct or helpful, you contribute to helping future readers with similar issues.
Abhijit
ServiceNow MVP
12 REPLIES 12
Abhijit already answered how to achieve with a coding solution, using gs.sleep()
do you need additional help?
Abhijit4
You can use gs.sleep(1000) // 1000 is time in ms.
Let me know if you have any further queries.
Thanks and Regards,
Abhijit
Abhijit
ServiceNow MVP
Ajay37
Hi @Abhijit ,
Thanks. Is it fine to use gs.sleep() in scheduled job? Can we get any challenges?
Yes, it is absolutely fine to use gs.sleep() in scheduled job. However, it will not work in scoped application.
Thanks and Regards,
Abhijit
Abhijit
ServiceNow MVP
In case if you would want to use it in scope app then you can follow below kb article, that's easiest and efficient way to achieve it in scope.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0962370
Thanks and Regards,
Abhijit
Abhijit
ServiceNow MVP
