What is COALESCE explain with example
‎10-04-2022 09:32 AM
Please Help me
‎12-18-2024 01:42 AM
Hi @Dan O Connor ,
what if we don't want to add fourth row(empid :004) which is not present in sn ?
‎01-07-2025 02:49 AM
Rows are records. This is data once loaded will appear as a record in a ServiceNow table.
If for example you had a data load with 10 records but only wanted to use lets say 7, you would just remove the three rows you don't want from the data file, so it doesn't import in the first place.
‎02-12-2026 06:06 AM
Thanks for the explanations.
‎09-19-2026 04:10 PM
Nice example @Dan - would also be worth mentioning that there is also an option to use multi-field coalesce meaning ALL coalesced fields must match for an update to occur. If any field differs, ServiceNow creates a new record.
So,
| Target Record | Incoming Record | Match Result | Action |
| John Smith | John Smith | Both match | UPDATE |
| John Smith | John Doe | First matches, Last differs | INSERT (New record created) |
and then we also have the dynamic / more advanced Conditional Coalescing. Think of it like "Search ONLY IF" especially useful when at times, incoming data has missing or bad information like "UNKNOWN", or is left blank.
Example: We have 100 People with ID = "UNKNOWN"
WITHOUT Conditional Coalesce (Standard Coalesce)
Person 1 ("Alice", ID: "UNKNOWN") arrives:
System searches for "UNKNOWN". Not found.
System creates Record #1: Name = Alice, ID = UNKNOWN
Person 2 ("Bob", ID: "UNKNOWN") arrives:
System searches for "UNKNOWN". MATCH FOUND! (It finds Alice).
System overwrites Record #1: Name = Bob, ID = UNKNOWN. (Alice is deleted/erased!)
Person 3 - and so until 100 arrive:
Each person matches Record #1 and overwrites the previous name.
Final Result in Database? Only 1 total record (Person #100). The other 99 people were overwritten and lost forever.
Now, WITH Conditional Coalesce
System sees "UNKNOWN" Rule triggers: "DO NOT SEARCH".
System creates Record #1: Name = Alice, ID = UNKNOWN.
System creates Record #2: Name = Bob, ID = UNKNOWN.
Person 3 - and so on until 100 arrive:
System bypasses the search for every row and creates Records #3 through #100.
Final Result in Database? 100 distinct records (Alice, Bob, Charlie, etc.), all safely stored in your system.
Please like and "Mark Helpful" if you liked my example & explanation. For you, it takes a second, for me, it does a great deal. Thank you! 🤗
‎09-30-2024 02:14 PM
I'm studying for my CSA and this was a simple explanation of coalesce and its use case. Thanks!
