What type of relationship exist among Incident, problem and Change management tables ?
Mahesh Jillella
Is there any relation between  following tables  , If exist what type of relationship is that
1. Incident
2.problem and
3.change management tables.
Narendra Kota
All these tables Incident, Problem, Change are extended from Task table in ServiceNow. Task is the parent table in ServiceNow, so most of the fields on this forms are derived from the parent Task table itself.
Also, you can create a Problem or Change from Incident, or, Change from Problem, or can create an Incident from Change request in cases where it is required.
Hope this helps.
Mark helpful or correct based on impact.
Thanks.
erik_brostrom
Mega Guru
Here is a brief overview..
Incident:
[rfc] - Change Request - Change which would be fixing the incident
[caused_by] - Caused by Change - Change which caused the incident
[problem] - Problem - Problem which the incident is related to
More information below for incident:
https://docs.servicenow.com/bundle/madrid-it-service-management/page/product/incident-management/tas...
Problem:
[first_reported_by_task] - First reported by task - Relates where the problem came from, this could be any [task] (i.e. incident, change, w/e)
[rfc] - Change Request - Change which would be fixing the problem
More information below for problem:
https://docs.servicenow.com/bundle/madrid-it-service-management/page/product/problem-management/task...
Change:
Could relate back to any task via the "Parent" field to where it came from, also the referenced fields above on the related records.
More information below for change:
https://docs.servicenow.com/bundle/madrid-it-service-management/page/product/change-management/task/...
More information can be found by looking at the dictionary entries for the specified tables and see the fields / their relationships.
