Embed Font Awesome Icons in Knowledge Base Articles
Thomas Bohan
Is there a way to embed Font Awesome Icons in a HTML based Knowledge Base Article please
I've tried adding code like
<i class="fas fa-info-circle"></i> This is an info icon.
but it gets removed.
11 REPLIES 11
Thomas Bohan
Here is an example of the HTML I'm trying to add:
Before
<html><head><link href="https://cdnjs.cloudflare.com/ajax/libs/font-awesome/6.4.0/css/all.min.css" rel="stylesheet"/></head></html><p><strong><span style="font-size: 18pt;">Create An Email Signature</span></strong></p>
<p><i class="fa fa-envelope" style="margin-right: 8px;"></i>To create a personalized email signature:</p>
<ol>
<li>Open a new message. On the <strong>Message</strong> tab, in the <strong>Include</strong> group, click <strong>Signature</strong>, and then click <strong>Signatures</strong>.</li>
<li>On the <strong>E-mail Signature</strong> tab, click <strong>New</strong>.</li>
<li>Type a name for the signature, and then click <strong>OK</strong>.</li>
<li>In the <strong>Edit signature</strong> box, type the text that you want to include in the signature.</li>
<li>To format the text, select the text, and then use the style and formatting buttons to select the options that you want.</li>
<li>To add elements besides text, click where you want the element to appear, and then do any of the following:</li>
</ol>
<table border="1" cellpadding="4" cellspacing="0">
<tbody>
<tr>
<td>
<p><i class="fa fa-sliders-h" style="margin-right: 8px;"></i><strong>Options</strong></p>
</td>
<td>
<p><i class="fa fa-question-circle" style="margin-right: 8px;"></i><strong>How to</strong></p>
</td>
</tr>
<tr>
<td>
<p><i class="fa fa-id-card" style="margin-right: 8px;"></i>To add an electronic business card</p>
</td>
<td>
<p>Click <strong>Business Card</strong>, and then click a contact in the <strong>Filed As</strong> list. Then click <strong>OK</strong></p>
</td>
</tr>
<tr>
<td>
<p><i class="fa fa-link" style="margin-right: 8px;"></i>To add a hyperlink</p>
</td>
<td>
<p>Click <strong>Insert Hyperlink</strong>, type in the information or browse to a hyperlink, click to select it, and then click <strong>OK</strong></p>
</td>
</tr>
<tr>
<td>
<p><i class="fa fa-image" style="margin-right: 8px;"></i>To add a picture</p>
</td>
<td>
<p>Click <strong>Picture</strong>, browse to a picture, click to select it, and then click <strong>OK</strong>. Common image file formats for pictures include .bmp, .gif, .jpg, and .png.</p>
</td>
</tr>
</tbody>
</table>
<ol>
<li>To finish creating the signature, click <strong>OK</strong>.</li>
</ol>
<h4>NOTE:</h4>
<p><i class="fa fa-info-circle" style="margin-right: 8px;"></i>The signature that you just created or modified won't appear in the currently open message; it must be inserted into the message.</p>
However after I added it it strips out all the Font Awesome Inco references within my content when I save it in the html editor editor as part of the article body.
After
<p><link href="https://cdnjs.cloudflare.com/ajax/libs/font-awesome/6.4.0/css/all.min.css" rel="stylesheet"></p>
<p>To create a personalized email signature:</p>
<ol>
<li>Open a new message. On the&nbsp;<strong>Message</strong>&nbsp;tab, in the&nbsp;<strong>Include</strong>&nbsp;group, click&nbsp;<strong>Signature</strong>, and then click <strong>Signatures</strong>.</li>
<li>On the&nbsp;<strong>E-mail Signature</strong>&nbsp;tab, click&nbsp;<strong>New</strong>.</li>
<li>Type a name for the signature, and then click&nbsp;<strong>OK</strong>.</li>
<li>In the&nbsp;<strong>Edit signature</strong>&nbsp;box, type the text that you want to include in the signature.</li>
</ol>
<table border="1" cellspacing="0" cellpadding="4">
<tbody>
<tr>
<td>
<p><strong>Options</strong></p>
</td>
<td>
<p><strong>How to</strong></p>
</td>
</tr>
<tr>
<td>
<p>To add an electronic business card</p>
</td>
<td>
<p>Click&nbsp;<strong>Business Card</strong>, and then click a contact in the&nbsp;<strong>Filed As</strong>&nbsp;list. Then click&nbsp;<strong>OK</strong></p>
</td>
</tr>
<tr>
<td>
<p>To add a hyperlink</p>
</td>
<td>
<p>Click&nbsp;<strong>Insert Hyperlink</strong>, type in the information or browse to a hyperlink, click to select it, and then click&nbsp;<strong>OK</strong></p>
</td>
</tr>
<tr>
<td>
<p>To add a picture</p>
</td>
<td>
<p>Click&nbsp;<strong>Picture</strong>, browse to a picture, click to select it, and then click&nbsp;<strong>OK</strong>. Common image file formats for pictures include .bmp, .gif, .jpg, and .png.</p>
</td>
</tr>
</tbody>
</table>
<ol>
<li>To finish creating the signature, click&nbsp;<strong>OK</strong>.</li>
</ol>
<h4>NOTE:</h4>
<p>The signature that you just created or modified won't appear in the currently open message; it must be inserted into the message.</p>
Thomas Bohan
I line example would be
becomes
I tested in my end but it remains the same..
Try to read this, if it might help you:
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0957850
Or you can try to play around with UI Properties, there are some options for fonts:
(no direct experience)
✂-----Cutting-out-the---✦AI-noise✦---All-replies-written-and-vouched-for-by-GlideFather---
Thomas Bohan
This is what it should look like (with the icons)
ahaaa and are you able to copy/paste the icons or are these little pictures?
