‎08-12-2025 06:52 AM
How can i set description and short description from flow designer on group approval. I have conditions after the approval is created to close the related case so have a if condition after that. If I try to do n update action would that work?
‎08-12-2025 07:47 AM
the "Ask for Approval" flow action doesn't allow you to set other field values.
So you will have to use before insert business rule on table "sysapproval_group" to set Description and Short Description
‎08-12-2025 07:42 AM
The description has to be set on the Approval not on case though. Once the Approval is created need to set these.
‎08-12-2025 07:51 AM - edited ‎08-12-2025 07:53 AM
You can use similar logic to update the field values. Do you need any help with the action ?
Bhuvan
‎08-12-2025 07:44 AM
so what did you start and where are you stuck?
share screenshots.
‎08-12-2025 08:00 AM
I created a business rule and got it working, I was trying to do that in a flow earlier.
