Difference in client scripts and catalog scripts
GowthamGr
Brief explination about client and catalog client scripts
4 ACCEPTED SOLUTIONS
Dr Atul - LNG
Client Scripts and catalog Client Scripts are virtually the exact same sort of script. The differences are that client scripts execute against a form with a certain type of record, whereas catalog Client Scripts execute against a certain catalog item or variable set within a catalog item.
https://www.linkedin.com/posts/servicenow-space_servicenow-servicenowspace-learning-activity-7413207...
yashkamde
Tera Sage
Hello @GowthamGr ,
There is nothing a much difference between them,
In short : Client Scripts apply to standard forms across the platform, while Catalog Client Scripts are tailored for Service Catalog item forms. Both are powerful tools to improve usability and enforce business rules at the client side.
SohamTipnis
Hi @GowthamGr,
In ServiceNow, a Client Script is used to control how a form behaves when a user is working on it. It runs in the browser and helps with things like making fields mandatory, setting them to read-only, validating inputs, or showing messages based on user actions. For example, you can make the “Close Notes” field mandatory when an Incident is being resolved.
A Catalog Client Script, on the other hand, works specifically for Service Catalog items. It controls the behavior of catalog variables (like dropdowns, checkboxes, or text fields) inside a catalog item. For example, you can show additional configuration options only when a user selects “Request New Laptop.”
In simple terms, both control form behavior — but Client Scripts are for normal forms, while Catalog Client Scripts are for catalog items.
Simple Difference
  • Client Script => Works on standard forms (Incident, Problem, etc.)
  • Catalog Client Script => Works only on Service Catalog items
If you find my answer useful, please mark it as Helpful and Correct. ‌‌‌‌‌😊
Soham Tipnis
ServiceNow Developer ||  Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
Aditya_hublikar
Hello @GowthamGr ,
A Client Script is used to control the behavior of form fields on standard tables (like Incident, Change, or custom tables) directly in the user’s browser. It helps with tasks such as validation, auto-filling values, making fields mandatory, showing messages, or hiding fields to improve user experience.
A Catalog Client Script works specifically on Service Catalog items . It is used to control catalog variables instead of table fields, allowing dynamic behavior like showing/hiding variables, validating user input, or setting default values during catalog request submission.
If this helps you then mark it as helpful and accept as solution.
Aditya
Aditya_hublikar
Hello @GowthamGr ,
Aditya
Mohit 101
Giga Guru
Hi @GowthamGr
1. Client Scripts
These are used to manage the behavior of standard forms across the platform.
Purpose: To automate field behavior, validate data, and provide real-time feedback to users on records like Incidents or Changes.
Examples:
Making a field mandatory only when a specific state is reached.
Displaying an alert or confirmation message before a form is saved.
Auto-populating a "Category" based on the "Short Description" field.
ServiceNow
2. Catalog Client Scripts
These are specialized scripts tailored specifically for the Service Catalog.
Purpose: To manage the appearance and behavior of variables within a Catalog Item or Record Producer.
Examples:
Hiding specific hardware options until a user selects "New Laptop".
Validating that a "Date of Birth" variable is not in the future.
Changing the available choices in one dropdown based on the selection in another.
Mark it helpful if this helps you to understand. Accept solution if this give you the answer you're looking for.
Thank You
its_SumitNow
Hi @GowthamGr
Both  Client Scripts and Catalog Client Scripts carry same functionality which is it works on UI level, & one more point to note is onCellEdit function is available only in client scripts not in catalog client script
I hope it helps, if helped kindly mark helpful & Accept as Solution 🙂
Sumit
Abhishek_W
Giga Guru
Hi @GowthamGr
Difference between Client Scripts and Catalog Client Scripts (ServiceNow):
  • Client Scripts: Run on any table/form (incident, change, etc.). Types: onLoad, onChange, onSubmit, onCellEdit. Stored in sys_script_client.
  • Catalog Client Scripts: Service Catalog only (items/variable sets). Types: onLoad, onChange, onSubmit (no onCellEdit). Stored in catalog_script_client. Applies to Catalog form + sc_task + RITM variables
    👍👍If you find this any helpful, then give a thumbs up and accept the solution ✔️.
Prathmeshda
Hello @GowthamGr
1) CLIENT SCRIPTS
These exist on standard tables (Incident or Problem, for example).
They are designed to handle data that already exists in your database.
Use these scripts when you want to control how a record form works, such as making fields required, read-only, or hiding and showing fields dynamically. It will target "Fields."
2)CATALOG CLIENT SCRIPTS
These exist in the Service Catalog.
They enable the “shopping” experience.
Use these scripts when a user is making a new request, such as ordering a laptop, requesting software access, or making a service request.It will target "Variables."
If you found this article useful, please mark it as Helpful. It helps others find the content more easily 👍
