Difference in client scripts and catalog scripts
GowthamGr
Brief explination about client and catalog client scripts
4 ACCEPTED SOLUTIONS
Dr Atul - LNG
Client Scripts and catalog Client Scripts are virtually the exact same sort of script. The differences are that client scripts execute against a form with a certain type of record, whereas catalog Client Scripts execute against a certain catalog item or variable set within a catalog item.
https://www.linkedin.com/posts/servicenow-space_servicenow-servicenowspace-learning-activity-7413207...
yashkamde
Hello @GowthamGr ,
There is nothing a much difference between them,
In short : Client Scripts apply to standard forms across the platform, while Catalog Client Scripts are tailored for Service Catalog item forms. Both are powerful tools to improve usability and enforce business rules at the client side.
SohamTipnis
Hi @GowthamGr,
In ServiceNow, a Client Script is used to control how a form behaves when a user is working on it. It runs in the browser and helps with things like making fields mandatory, setting them to read-only, validating inputs, or showing messages based on user actions. For example, you can make the “Close Notes” field mandatory when an Incident is being resolved.
A Catalog Client Script, on the other hand, works specifically for Service Catalog items. It controls the behavior of catalog variables (like dropdowns, checkboxes, or text fields) inside a catalog item. For example, you can show additional configuration options only when a user selects “Request New Laptop.”
In simple terms, both control form behavior — but Client Scripts are for normal forms, while Catalog Client Scripts are for catalog items.
Simple Difference
  • Client Script => Works on standard forms (Incident, Problem, etc.)
  • Catalog Client Script => Works only on Service Catalog items
If you find my answer useful, please mark it as Helpful and Correct. ‌‌‌‌‌😊
Soham Tipnis
ServiceNow Developer ||  Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
Aditya_hublikar
Hello @GowthamGr ,
A Client Script is used to control the behavior of form fields on standard tables (like Incident, Change, or custom tables) directly in the user’s browser. It helps with tasks such as validation, auto-filling values, making fields mandatory, showing messages, or hiding fields to improve user experience.
A Catalog Client Script works specifically on Service Catalog items . It is used to control catalog variables instead of table fields, allowing dynamic behavior like showing/hiding variables, validating user input, or setting default values during catalog request submission.
If this helps you then mark it as helpful and accept as solution.
Aditya
VaishnaviK3009
Hi @GowthamGr !!
Client Scripts
  • Run on the client-side (user’s browser).
  • Used to control form behavior, like:
    • Show/hide fields
    • Make fields mandatory
    • Validate data before submission
  • Types: onLoad, onChange, onSubmit, onCellEdit.
  • Specific to Service Catalog items.
  • Run in the Service Catalog form (when ordering items).
  • Can control variables, validate user input, and dynamically update the form.
  • Types: onLoad, onChange, onSubmit (similar to client scripts but for catalog items).
Mark this as Helpful if it clarifies the issue.
Accept the solution if this answers your question.
Vaishnavi
