Create Attachments using GlideSysAttachment()
Mussie
Hi Guys,
I would like to get an attachment from sys_attachment table and edit it and re-attach it as a different file. I have the below code, but it isn't working? Can you please check what is missing?
//fetch the attachment file that needs to be edited
var attachmentGR = new GlideRecord("sys_attachment");
attachmentGR.addEncodedQuery('GOTOtable_name=ecc_agent_attachment^content_type=test/csv^file_nameSTARTSWITH1');
attachmentGR.orderByDesc('sys_created_on');
attachmentGR.query();
if(attachmentGR.next()){
var table_sys_id = attachmentGR.table_sys_id;
// read the attachment...
var stringUtil = new GlideStringUtil();
var sa = new GlideSysAttachment();
var binData = sa.getBytes(attachmentGR);
// convert it to Encoded Data..
var encData = stringUtil.base64Encode(binData);
// decode the encoded data into string..
var csv_string = stringUtil.base64Decode(encData) + '';
var csv_array = csv_string.split("\r\n");
var new_csv_array = csv_array.shift(); //removes the first row, edit file
// convert this back into a CSV string...
csv_string = new_csv_array.join("\r\n");
// attach it back...
var base64EncodeString = stringUtil.base64Encode(csv_string);
var data = stringUtil.base64DecodeAsBytes(this.base64EncodeString);
//attach the attachment.
var attachment_sys_id = attachment.write("ecc_agent_attachment", table_sys_id, "1111", "test/csv", document);
Mussie
Hi Mussie,
The original code should work with the changes I suggested.   Try this:
  csv_string = csv_array.join("\r\n");
  var attachment = new Attachment();
  var attachment_sys_id = attachment.write("ecc_agent_attachment", table_sys_id, "1111.csv", "test/csv", data);
Shagun Gupta
Can you please help me with the code for a dynamic attachment in a notification?
Requirement is - User is selecting Request Type as Export Group Members and file should be sent to Requested For with the list of Group members in that particular group.
File varies from group to group. Please help me with the code for this.
