Display custom dialog box
NehaReddyH
I have a dropdown field "status" on my form and im looking for a way to create a dialog box with three options "cancel", "cancel but dont send" , "send". When a user changes a status to cancel, this dialog box should appear with these three options and when user clicks on send, a notification should be sent. When 'cancel but dont send' is selected then status will be updated. I dont have much knowledge on UI page scripting. Can anyone help me to achieve this functionality?
Thanks in advance!
Hi Neha,
I don't think directly you can use "cancel_project_button" in processing script
only html hidden element id's can be access directly in processing script
please update code as below
HTML:
After line 4 add this line
<input type="hidden" id="hiddenElement" name="hiddenElement"/>
in client script make this change for both the functions
Client Script:
after line 6 add this
gel("hiddenElement").value = 'cancel clicked';
after line 11 add this
gel("hiddenElement").value = 'send clicked';
now in processing script check this
Processing script:
if(hiddenElement == 'cancel clicked'){
gs.info("cancel project called");
//send notification
else{
gs.info('send button clicked');
13 REPLIES 13
and im using onchange clientscript
Hi Neha,
if you are in custom scope app then please give the complete endpoint of the UI page in the GlideDialogWindow
Thanks! that worked.
can you help me with retrieving the button value in processing script? Im setting the value in client script.
I tried logging but dint get any log.
<button class="btn btn-primary" id="send_button" onclick="sendAction()" style="min-width: 5em;" title="" type="submit">
Send
</button>
In processing script:
function sendAction(){
gs.info(send_button);
Glad to know it worked.
the processing script would execute only when you use <g:ui_form> tag in HTML.
what value you want in the processing script?
please explain the requirement with UI page screenshot
This is how i have been trying to get the element value in processing script but its not working.
if(cancel_project_button == 'cancel_project'){
//send notification
