Execute Now button is not executing the code of scheduled job
kamlesh kjmar
I have written a scheduled job to execute daily at 6 am. After writing the code when I saved it and clicked on execute now button, page refreshes but it do not do anything i.e. script do not executes.
But when I copy the same code and executes it from Background script it works perfectly fine. Any idea why is that ?
12 REPLIES 12
Please apply cross scope privileges between both your scoped app tables.
https://docs.servicenow.com/bundle/kingston-application-development/page/build/applications/reference/c_CrossScopePrivilegeRecord.html
Sachin
Matthew Smith
Hi Kamlesh
Type sys_trigger.list into the Filter Navigator and sort the records by created. This should tell you if the Scheduled Job is triggered or not.
If yes, then there must be an issue with the script.
Matt
Hi Matt,
I checked that as well. Scheduled job didn't execute at all. Is it because my schedule job is in different application i.e. not global. If yes then is this behavior expected ?
Kamlesh
Yes that is possible if global application scope does not have access to edit the records in your scoped app,
Amarjeet Pal
Hello Kamlesh,
Did you figured solution for this.
Amarjeet Pal
