Flow Designer approval problem using a For Each loop
Sergio26
I'm working on a flow and I have a problem understanding the approval logic logic when used in a For Each loop action.
I have a record producer (on the 'facilities_request' table) with a list collector variable which contains a list of locations (reference to the 'cmn_location table').
In the catalog form, the user can select locations for which he wants an access to granted on his employye card. When the request is created a task is created for each location and an approval is sent to the location owner to approve or not the access.
1- My first step is to get the selected locations in the variable. I'm doing this by a custom script action and I output the sys_id of each locations.
2- Then I look up for each record on the 'cmn_location' using those sys_id.
3- Then I use a For Each loop action to create a facilities task for each location access.
When I'm doing this and test it everything is fine and I get one task for each location selected.
However when I include a 'Ask for approval' action after the task creation, there is only the first task that is created with the correct approver but the other tasks are not created.
The approval on the first task needs to be approved/refused and only then the second task is created with the correct approver and so on.
My goal is to create all the tasks with the approvals at the same time.
Anyone can help me?
Thank you
ServiceNow Tec2
This has been resolved by ServiceNow Technical Support. Please refer to KB0762101 for more information.
I'm working on a subflow and on that flow I need to take the approval from group managers then have to create the record on sys_user_grmember table. Still below flow is not working and approval for 1st group record is triggering but for remaining it is getting skipped.
Hello, I have a same use case to implement. Did you find a solution for that?
Hi, so the approval should be in the subflow, but in that case the approval will be on Catalog task level, not on RITM?
