Flow Designer>>Look Up Record>>Flow stops in error if no record found
Stefan K_
Use case: I want to check if a certain record exists
  • If yes, update another record by inserting the look up record to a reference field
  • If does not exist, do something else
Problem: When using "Look Up Record" function, if there is no record found the whole flow stops with error:
Question: What is this error? I only noticed it happens if no records found. Is this by design and if yes, how should you manage a situation to check if something exists and continue if doesn't? Look Up Record(s) is not usable because you can't use it as a data pill to populate a single reference field.
I'd suggest you do use "look up record(s)" in a way similar to this:
 As you can see, you can still then use the data pill to reference the record.
Marshall Burns
Kilo Explorer
Where do you get "Count" from?
Ok I see, I was doing just look up record, instead of look up records so there was no count.  If you only want to look up a single record it doesn't seem like you can tell if you got it or not.
