Flow Designer "IF / ELSE" flow logic issue
‎04-26-2019 05:29 AM
I've been wrestling with an issue in Flow Designer for several days and will post several questions on this topic. For this post, I setup a scenario to better understand how Flow Designer is supposed to work. See screenshot below.
Refer to 3.3.1. If the If statement on 3.2 evaluates to False and 3.3 shows Completed, why does 3.3.1 show Not Run. To me, this appears to be a bug. Note, this ties into a larger issue I'm having, but I first wanted to understand this step. If you look at step 2, the Assign Subflow Outputs status is Completed. I wanted to show what I would expect to show in 3.3.1, that the step is Completed.
Here's the subflow being called from within a larger workflow.
I attempted to use an IF statement (step 2) to evaluate the Subflow Output value to determine if it is True. My test case should have returned True. Notice on step 2 that the IF statement evaluated to False, which is wrong. Also, I'm confused by the RUNTIME VALUE. It shows {0:B}=true. What does this mean? If anything, I would have expected it to return {0:B}=false. But I don't understand yet how to interpret the runtime values.
Flow Designer
- 13,702 Views
‎06-03-2019 11:37 AM
I'm also having this issue. I'm attempting to evaluate and filter based on three different conditions. However, when I add in a third If or Else If, one of my conditions ends up not getting evaluated altogether, coming up with the Not Run notification. I think this may be a system error or a bug with Flow Designer.
‎06-03-2019 12:39 PM
You're probably right. I confirmed that Flow Designer has a lot of issues in London. I just upgraded my personal developer instance to Madrid and will continue testing and report back.
‎07-12-2020 12:21 PM
Hi everyone i am on Orlando Version and also experiencing this issue. has a resolution been found ?
‎04-08-2021 09:54 AM
Old thread but if anyone is still looking for a workaround. I am running Paris and still having this issue, Else does not run the steps underneath.
I ended up using else if (rejected or cancelled), that seems to run fine.
