12-29-2020 06:59 AM
I am trying to get the context id of the executing flow designer within the sub flow of flow designer?
The API provided in https://developer.servicenow.com/dev.do#!/reference/api/orlando/server/sn_fd-namespace/ScriptableFlowAPI only speaks about getting the contextId if the flow is executed through script...more aptly getting the context id after the execution of the SUBFLOW is triggered .
For example , adding "worknotes link action" adds the flow to the worknotes similarly i was trying to query on the context id after creation .
The whole idea is to have an active check for the flow execution and raising a task if any error arises on using oob AD spokes.
Because for some reasons often randomly the flow is failing due to powershell script failing to execute.
Shariq
Flow Designer
01-03-2021 09:13 AM
Hope you are doing good.
If so, please mark appropriate response as correct & helpful so that the question will appear as resolved for others who may have a similar question in the future.
If not, please let us know if you need some more assistance.
Thanks!
11-10-2021 10:19 AM
Can you please tell me How to find relation of Context to the record?, I have checked with record sys_id in the Context sys_id. Its not there....
I need a relation of a flow for a particular case so that I can cancel the Flow Execution.
Thank you for your response.
