How to hide rating and helpful link from article
Prakash_S
Can we hide rating and helpful link from article? if yes then how?
Runjay Patel
Hi @Prakash_S ,
Yes you can set the property to false.
Part 2. In this video i have talked about overview on ServiceNow platform/tool. How you can opt for personal dev instance (PDI)? how to login in ServiceNow instance and navigation to OOB modules. For document please visit: https://servicenowwithrunjay.com/ Follow Facebook page for latest update on
PritamG
Mega Guru
yes, you can hide the rating and helpful link from an article by modifying the widget or UI component.
Edit the widget used for knowledge articles then remove or comment out the html code for rating links. alternativly, use css in the theme to hide them:
use code-
.rating, .helpful-link{
     display: none;
