How to remove KB articles which are 5 years old, i tried Flow Designer but no use. Can you please help me.
teja25
Im trying to remove kb articles which are published more than 5 years, using flow designer. but no luck it is not picking up anything.find_real_file.png
this is the trigger im using,
as part of developing im trying to change to valid to certain date.
Please give me any suggestions if we can try another way.
teja25
im not sure why i cannot see this knowledge record showup
There is a tiny difference.
You are using "Lookup record" (gets just one record)
I used "Lookup records" (gets one or more records defined by query)
Change that, and it will work for you.
