How to Schedule a Flow to Run Quarterly in ServiceNow Flow Designer?
Andrew Meza
Hello everyone,
I’m trying to create a Flow Designer flow that automatically creates a record (form/task) quarterly on January 1, April 1, July 1, and October 1.
Here’s what I’ve tried so far:
  • Using a Scheduled trigger with the “Repeat” option, but it only allows repeating in days, not months or quarters.
  • Using the Monthly trigger on the 1st day of each month combined with an If condition to check the month — but I don’t see a way to add scripts or dynamic conditions in Flow Designer.
  • Looking for a way to add script logic during the flow to check if the current month is one of the quarterly months, but I can’t find how to do that in the standard Flow Designer UI.
My question:
  • What is the best way to implement a true quarterly scheduled flow in ServiceNow Flow Designer?
  • Is there a way to use scripts or logic in the flow to filter months?
  • Or should I use a different method (Scheduled Script Job, IntegrationHub, etc.)?
Any guidance, examples, or best practices would be greatly appreciated!
Thank you!
J Siva
Hi @Andrew Meza
Check out the below community post.
Need help on trigger notification quarterly
Siva
