How to set requested for in RITM using Cart APi is it possible?
Gowtham Kodali
I am using Cart api to set Requested_for field for different users,but still the requested for is showing my name only
is there any way to set the requested_for by using Cart API
Ankur Bawiskar
@Gowtham Kodali
Unfortunately you cannot set any fields of REQ or RITM using Cart API
the only way is to get the REQ sys_id and then set the value
sample script below
var cartId = GlideGuid.generate(null);
var cart = new Cart(cartId);
 //add your requested item to the cart by sys_id of the catalog item
var item = cart.addItem('4054428fdb151f0097679ec6db9619c0', 1);
//fill in the variables on the request item form
cart.setVariable(item,"u_requested_for", "e80edd6edbec6bc097275e25ca9619a4");
cart.setVariable(item,"contact_number", "0");
cart.setVariable(item,"assignment_group", "87ec1c342b2e71406c487fb5a8da1524");
cart.setVariable(item,"application_service", "cdedfbcedb0f9744c291c170ba9619a7");
var rc = cart.placeOrder();
var reqRecord = new GlideRecord('sc_request');
reqRecord.get(rc.sys_id);
reqRecord.requested_for = 'user sys_id you want here';
reqRecord.update();
16 REPLIES 16
@Garima13
Can you post a new question for this as this is an older thread? please tag me there
Posted a new question. If you could please help me in figuring it out.
https://www.servicenow.com/community/developer-forum/rest-api-explorer-mapping-date-fields/m-p/26657...
JeevesS
Actually you can set the RITM field "Requested For" via below code
var reqfor = '6frd2rr3rrrrrre110d82afcc6cebb3ree'; // Requested for users sys_id to set
var cart = new sn_sc.CartJS();
var item = {
'sysparm_id': '345b2ad7873310ed0d82afcc6cebb33f4', //Catalog Item sys_id
'sysparm_quantity': '1',
'variables': {
'some_variable': "Test",
var cartDetails = cart.addToCart(item);
cart.setRequestedFor(reqfor); //Add thisinbetween here
var checkoutInfo = cart.checkoutCart();
Willem
Tera Sage
You can, using cartJS:
cart.setRequestedFor("039c516237b1300054b6a3549dbe5dfc")//sys_id of the requested for you want
var item =
'sysparm_id': '0d08837237153000158bbfc8bcbe5d02',//sys_id of the item
'variables':{
'contact_number': '0',
//add more variables here
Also refer to:
https://developer.servicenow.com/dev.do#!/reference/api/orlando/server/sn_sc-namespace/c_CartJSScope...
Gowtham Kodali
I have around 700 records with different values for RITM variables all are there in excel sheet, how can i proceed with above script ?
should  I manually update the variable values one by one in the above script and run that script or is there any other way to proceed
