Incoming email in flow designer not showing Body Text.
Allen12
Body Text is not showing any data. Any help would be appreciated.  Once I Get this done I need to pull the CI out of the email to be able to assign to its Owner.
find_real_file.png.Here is a sample email
Action:
Please verify, by opening the email record, and select "Show XML" and verify that body_text contains any data.
9 REPLIES 9
OlaN
Tera Sage
If you open that email record, does the field "body_text" contain any data?
The image you attached shows the text from the "body" field of the email record (which is not the same as body_text field).
Yes, that is what the Sample email is showing. Also if I click on the sys_id of the incoming email, it will also show the details.
I've converted it to body.  It seems to be working.  Thank you.  Any idea how to rip my CI from the body text?
