Integration Hub - Remote Instance Spoke - Update Remote Record action not available in FD
tejakanchustamb
Giga Contributor
I recently enabled the Remote Instance Spoke for Integration Hub and am trying to configure a flow using the "Update Remote Record" action. However the action is not available for selection. Testing the action throws the below error.
There was an error executing the action:Bad Request. Could not retrieve Action for publish, unknown id: 20c0df61939910106b543511e57ffbd4
Has anyone else encountered this issue? I would really appreciate some guidance/ assistance.
tejakanchustamb
Giga Contributor
Thank you for your response. This is a bug that HI Support fixed. Snapshot records were missing on a couple of actions and the fix was to add the missing records to the instance.
tejakanchustamb
Giga Contributor
