12-15-2017 10:59 PM
Hi ,
it 's became hard challenge to me, i hope you will help me on this.
Issue:
When user is clicked on YES or NO button in KB ARTICLE then immediately Make Comments box mandatory OR display Prompt box(message box) with message .
for this i tried to check UI Macro's(it is in readonly) , UI pages but i am unable to understand where need to do changes.
At least please tell me is it possible or not to display POPUp box on article form
Need Rusult like this , not exactly like this, need this kind of format.
12-16-2017 11:20 PM
Hi Karthik,
I did find the Helpful message is out of box and here is the way you can add an alert on click of Yes.
Go to UI Macro -> search for XML contains Helpful? you should find this ui macro 'kb_view_ratings'.
within this UI macro you will see that a function feedback is being called on click of Yes search that and update as per below screenshot:
Test it now.
Working fine screenshot below:
Remember that this will be a global change since this ui macro is applicable for all records.
Mark Correct if this solves your issue and also hit Like and Helpful if you find my response worthy based on the impact.
12-16-2017 11:20 PM
Hi Karthik,
Test it now.
