Run Flow Executionwith ATF
OMT
I should run a Flow Execution for the incident to check whether an SMS has been sent. Is it possible with ATF to run the flow to trigger the sending of SMSs?
3 ACCEPTED SOLUTIONS
Ankur Bawiskar
@OMT
flow runs in background and is server side logic and can't be checked with ATF.
Please close the thread buddy.
OMT
closed, buddy 😄
11 REPLIES 11
I don't know all the technical details of your situation but for example, if your flow is triggered when a Priority 1  Incident is created to send an event to trigger an SMS, I would:
  1. Impersonate a user entitled to do that
  2. Record Insert a P1 Incident
  3. Record Validate or Record Query there is an event with the correct parameters.
Hi @OMT ,
Any feedback on this topic? Were you able to make progress?
I am curious to know the outcome and hopefully improve the resolution if this topic. There are not many things you cannot do with ATF.
