What exactly is a DB Drain in ServiceNow platform?
KarenFinlay
ServiceNow Inc. has created various DB Drain change records for our instances in the past few months; however those are not accompanied by the usual KB Article with additional information; so I will like to know:
1. What exactly is DB Drain in ServiceNow platform?
2. What are the steps for ServiceNow DB Drain?
3. What is the end goal of the DB Drain?
The article you are sharing is about a different subject? "Tips for reducing instance database footprint"
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Thanks for reviewing, updated that link with your one.
