04-24-2025 01:25 AM
Hi all,
We use interactions and when we associate an interaction to an incident for example is it possible to get a work note into the ticket it has been linked to saying IMS...... has been linked?
04-24-2025 02:05 AM - edited 04-24-2025 02:32 AM
Hi @joshmorris
Yes. It's possible.
Create one After Business rule on interaction_related_record table like below.
var task_rec = new GlideRecord('task');
task_rec.get(current.task.sys_id);
task_rec.work_notes = current.task.getRefRecord().number +' has been associated with '+current.interaction.getRefRecord().number;
task_rec.update();
})(current, previous);Hope this helps.
Siva
04-24-2025 02:44 AM
you can use flow designer for this with no scripting
Flow Triggers when Insert on "interaction_related_record" and updates the INC
something like this but please enhance
04-24-2025 04:17 AM
@joshmorris Yes, you can. PFB script and make changes as required.
// Add your code here
task_rec.work_notes = current.task.getRefRecord().number +' has been associated with '+current.interaction.getRefRecord().number+'\n'+'Short description: '+current.interaction.getRefRecord().short_description;
task_rec.update();
})(current, previous);Output:
04-24-2025 02:44 AM
04-24-2025 05:54 AM
Did you get a chance to check the above flow I shared which has no scripting involved?
You should try to leverage flow with low-code/no-code wherever possible.
You could have enhance it further as per your requirement.
As per new community feature you can mark multiple responses as correct.
If my response helped please mark it correct as well so that it benefits future readers.
