12-08-2024 11:06 PM
I need help for my service now PDI. Numerous time I have refreshed my instance but still it says instance is offline and try few minutes later. Why it is showing again and again like this since last 5 hours.
If anybody knows about it please share your knowledge.
12-08-2024 11:18 PM
Hello @karangoswam
I encountered a similar issue recently, and my instance became available again after 2-3 days. I recommend waiting patiently for a couple of days, as it might resolve itself. However, if you haven't used your instance for more than 10 days, ServiceNow may reclaim it. If the instance remains offline even after 3-4 days, you may need to release the current instance and request a new one.
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps others find the solution more easily and supports the community!"
Thank You
Juhi Poddar
12-09-2024 12:27 AM
Hi @saumyachauhan59 I guess as @Juhi Poddar suggested If we are okay in losing the data that we have in current instance then we can proceed with releasing the current instance and getting the new one.
And regarding support I am not exactly sure whom to reach out here.
12-09-2024 12:35 AM
Hello @saumyachauhan59
Unfortunately, ServiceNow doesn’t provide direct support for Personal Developer Instances (PDIs). You can either wait a bit longer for it to come back online or release your current instance and request a new one.
Thank You
Juhi Poddar
01-10-2025 05:00 AM
https://dev182644.service-now.com/login.do instance is offline since around 1h from now. Please help to make it online. Thx!
01-10-2025 06:49 AM
Hi @magdalenapy
I've been using PDI without any issues since this morning, but I've noticed several posts in the community about PDI being offline. Here are some points to consider:
- There is no support available for PDI.
- If you can wait, let's wait a bit longer.
- You can release this instance and start a new one, but you will lose your previous data. To avoid losing update sets in the future, make sure to take regular backups of your PDI.
There have been 3-4 posts in the community today about PDI failures or unavailability. Based on the responses, you might need to wait 1-2 days and hopefully, the PDI will be back online.
