06-08-2026 05:38 AM
I am unable to access my Personal Developer instance from last 2 weeks. From last 2 weeks on wards its showing instance undergoing unscheduled maintenance.
Can anyone help me with this.
Surendra
06-08-2026 05:55 AM
I've been using PDI without any issues since this morning, but I've noticed several posts in the community about PDI being offline. Here are some points to consider:
- There is no support available for PDI.
- If you can wait, let's wait a bit longer.
- You can release this instance and start a new one, but you will lose your previous data. To avoid losing update sets in the future, make sure to take regular backups of your PDI.
There have been 3-4 posts in the community today about PDI failures or unavailability.
06-08-2026 06:00 AM
Hello @surendrad698805 ,
Since ServiceNow PDIs do not have dedicated support, you can either wait for some time and see if the instance comes back online, or request a new instance. However, if you request a new instance, all data from the previous instance will be lost.
Also, keep this in mind: always take regular backups of your work using Update Sets. This helps you recover your customizations and development work in situations like these.
If this helps you then mark it as helpful and accept as solution.
Aditya
06-08-2026 07:33 AM - edited 06-08-2026 07:33 AM
These days , it is happening to some of community members.
If your your Servicenow Developer PDI has been stuck in a "launching," "waking up" , "500 error" or not getting online state for more than 24 hours, then I will advice you to release the instance and request a new one .
As you know there is no support available for PDI.
06-15-2026 02:47 AM
Hi @surendrad698805,
If your Personal Developer Instance has been showing "Instance undergoing unscheduled maintenance" for more than two weeks, that's not normal. In most cases, temporary maintenance lasts only a short period.
First, try logging into the Developer Portal and check whether the instance is still listed under Manage Instance. If available, look for options such as Start Instance, Wake Up Instance, or Request Instance.
You can also try releasing the affected instance and requesting a new one if that option is available and you do not need the existing data.
Since the issue has persisted for two weeks, it's unlikely to resolve on its own, so contacting the Developer Program support team would be the best next step.
Hope this helps, and let us know if you're seeing any error messages when trying to access the instance.
If you find my answer useful, please mark it as helpful and correct😊.
Soham Tipnis
ServiceNow Developer || Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
