08-05-2025 04:37 AM
How do I have business requirements and risks organized and associated, what tool or artifact is recommended to be used?
08-05-2025 06:53 AM
For Business Requirements, refer below
https://www.servicenow.com/community/spm-forum/requirement-management-application/m-p/1049152
For Risk Management, you can refer GRC module
https://www.servicenow.com/au/products/risk-management.html
Bhuvan
08-05-2025 10:28 PM
Yes, what you're looking for is 100% doable.
The business requirement in the case of GRC is usually related to compliance and standards, which you can map to business processes and other elements. From there, you can set up the entire process around risk and mitigation.
To understand this better, I suggest going to Now Create → Assets → GRC: Risk & Compliance. You'll find process workshops and decks there that will give you a good idea of how it works.
Also, I’ve launched my GRC playlist on my YouTube channel, which could be helpful as well.
