How to define dynamic approval creation using approval activity in workflow.
‎06-22-2023 04:53 AM - edited ‎06-22-2023 04:54 AM
Hi ,
I am facing issue to define dynamic approval in the approval activity. Please find the code.
workflow.scratchpad.approver is storing username and is defined in the runscript of the wf. If workflow.scratchpad.approver is a member of the below group, then it would go to 2 approvers. else the approval will go the variable as mentioned as primary owner.
For the below, the approval is getting skipped.
//--------------- For Item XXXXXXX ------------------
else if (item == "XXXXXXX") {
if(workflow.scratchpad.approver.isMemberOf('Group'))
answer = ['4f7a90c9dbb5a700ce59a155059619c6', '8df91445dbb5a700ce59a15505961922'];
else {
if (workflow.scratchpad.request_type == "create" || workflow.scratchpad.request_type == "delete") {
answer = [current.variables.primary_owner];
var answer = [];
answer.push(current.variables.primary_owner);
answer.push(current.variables.new_primary_owner);
Could you please help me with the above code so that the approval goes to the mentioned sysids else primary owner.
‎06-22-2023 08:15 AM
Hi @Ankur Bawiskar , How to mention two individual approvers so that if anyone of the approver approves, it proceeds the next step. Could you please confirm this ?
if(gs.getUser().getUserByID(workflow.scratchpad.approver).isMemberOf('Group'))
‎06-22-2023 09:30 AM
that is defined in workflow activity
‎06-22-2023 10:59 AM
Thank You for your help @Ankur Bawiskar . It is working now.
‎06-22-2023 08:42 PM
