07-03-2025 07:24 AM
Is there a workflow sample that is available for the Agile development 2.0 tool connections. I cannot seem to find one. I have started to walk through the connector but there seems to be an issue and not sure what I am missing. It appears to have made the connection but when I do resume setup for next steps it States it is still connecting and in progress and Discovery is also in progress.
Is there a specific configuration that needs to be done in the Agile 2.0 area. I also assume there may be a permissions connection but don't see that ability.
07-08-2025 06:59 AM
I think in this case, you need to log a Now Support case as in my PDI it is fine in your case it is not working.
@Sai Teja1 any support here?
08-29-2025 03:30 AM
In Agile Development 2.0 workflow integration with digital product release often requires validating connector permissions and ensuring API endpoints are authorized. Discovery loops usually stay “in progress” if role based access or environment variables aren’t configured. At CONTUS Tech in digital product development, best practice is mapping user roles, enabling webhook callbacks and verifying CI/CD pipelines for seamless integration.
