12-12-2023 09:03 AM
Hi Community,
I have a scripted control indicator which runs monthly and generates supporting data in the indicator result. Currently, the supporting data is in a list view and shows the 'live record'.
This view of the records does not allow for the records to be extracted in xlsx or csv format (or any format for that matter). The Indicator Result system table is set-up this way.
It's likely a long shot, but is there a way to allow for the records to be extracted via xslx or csv?
12-12-2023 10:13 PM
Hi @Connor Meyer ,
The above list is developed using a UI macro and UI formatter.
You can find them in below URL's
<instance>/now/nav/ui/classic/params/target/sys_ui_macro.do%3Fsys_id%3D63882935c333020044b2db1122d3aed3
<instance>/now/nav/ui/classic/params/target/sys_ui_formatter.do%3Fsys_id%3D8bc8a935c333020044b2db1122d3ae14%26sysparm_record_target%3Dsys_ui_formatter%26sysparm_record_row%3D3%26sysparm_record_rows%3D5%26sysparm_record_list%3DtableCONTAINSindic%255EORDERBYname
We store this data in a columnar format in sn_grc_indicator_supporting_data table. We are not providing any option to extract this information as of now. Please customise based on your needs for now. I will see if we can incorporate this requirement into our product.
Naveen
07-18-2024 04:38 AM
Are there any updates? Our organization would also like to have this option.
08-19-2026 02:35 PM
We've asked ServiceNow to create an easy extract solution but after a few years there is still nothing available OOTB. We created our own "extract" UI action and it works pretty fast and pulls the entire indicator result from the underlying table.
